Transfer flight plan to Garmin G3X
Hi
We’re getting an aircraft with a G3X soon
What’s the easiest way to transfer a flight plan created in vfrnav to the G3X?
With SkyDemon there’s a function that sends the plan directly to the Garmin Pilot app and from there to the G3X.
Thomas
Hi Thomas,
We had a similar question some time ago in our email support.
I can’t quite remember, but I think there was an app that handled transferring the flight route to Garmin hardware. The transfer to that app was done via the share function directly from the VFRnav route planner.
Could that be? I myself have no experience with Garmin devices.
Hello Hermann
Yes, as described above, that works with SkyDemon and the Garmin Pilot app.
But with vfrnav?
Thomas
In VFRnav flight planning, the Share option is in the top-right of the menu. Try going through all the formats there to see whether the Garmin app can be selected in the list below.
I think that’s how it was.
Hello Thomas,
I’ve just noticed that I think I mixed that up. What I had in mind was a Dynon system — not Garmin. That ran via a “companion app” to get routes onto the hardware.
For Garmin we lack documentation for the protocol. I’ll add this to the to‑do list again and check whether we can make progress on it. Unfortunately, we don’t have access to a Garmin device to test the transfer ourselves.
Good evening everyone,
The upcoming release will include the option to send routes to the Garmin Pilot app, which in turn enables sending the route to Garmin EFIS units such as the G3X.
In the long term, it would make more sense to avoid the “detour” via the Garmin app and send the route directly to the EFIS.
For the initial analyses we are looking for users who have a Garmin EFIS (e.g. G3X) in their aircraft. It is important that it has the appropriate Bluetooth capability. The G3X is available, for example, in two variants: the G3X and G3X Touch. Only the latter offers Bluetooth compatibility out of the box.
If you are interested, please email mail@flugbetrieb.com
Hermann, I’ve sent you an email.
Thomas
Hi Thomas,
yeah — got it :+1:. Sorry — I won’t be able to reply to you in detail until this afternoon.
Hi
When I use the “Send to Garmin Pilot” feature, the Garmin Pilot app opens, but then nothing happens.
Normally the app should then ask if the flight plan should be imported.
Tested on Android.
Thomas
Hello Thomas,
Is there anything “special” about the route, or is it a simple direct route from point A to B?
Which version of Garmin Pilot do you have on your Android device?
Route:
Kassel Calden EDVK via mandatory reporting points S1 and S2 to the Pohlheim glider airfield.
Version 26.10.0
Thomas
Oh, yeah - there was a much older version on our test device :see_no_evil_monkey:
Thanks for testing, Thomas :+1:
The update will be released later this evening.
My Garmin Pilot doesn’t recognize glider airfields or their identifiers, so the transfer doesn’t work. For other airfields with an ICAO identifier, transfers from VFRnav work great. However, I also still have an old 25-something version. But I don’t need it anyway :grinning_face:
@H655 Thanks for the update and the great development :ok_hand:
Evening
On Apple, the transfer works if you actually use airfields with ICAO codes.
But when I now, in Pilot, add to the existing route by clicking on the line to insert another point somewhere out in the countryside, Pilot treats that as a free point with coordinates. A glider airfield is nothing other than coordinates with a name.
The mandatory reporting points in Kassel are also shown in Pilot only with coordinates and not with names.
And when I zoom into the map in Pilot, the mandatory reporting points transmitted by vfrnav are a few meters away from the ones named in the Pilot app.
Thomas
Next attempt
I’m not selecting the glider airfield directly as the destination; instead I click in vfrnav a few metres next to the reference point of the field and create a free point on the map as the destination in the vfrnav flight planning.
This point is imported into the Pilotapp without any problems.
Thomas
I assigned a name to the generated waypoint in VFRnav.
The waypoint still imports into Pilot perfectly. Only the name is not carried over.
So it must be due to how glider airfields are set up in VFRnav.
Thomas
Another try
A route from the glider airfield Butzbach-Pfingstweide to the glider airfield Vielbrunn is being flagged as an error in Garmin Pilot and is not imported.
If I move the start and end points on the map in vfrnav by a few metres, the export to Garmin works.
@H655 will you take a look at the problem, or is it too much effort for only a few users with G3X?
Thomas
Hi Thomas,
have you tried it with the new version? Android has already been rolled out.
I don’t understand the question :slight_smile: I already wrote that an update for this is on its way.
@H655
Actually, I hadn’t noticed that 4.31.1 was out.
I had to update manually.
Now it also works with the non-ICAO airfields.
Great job, Hermann.
Could you make it so that the names of the airfields, and not just the coordinates, are shown on the Garmin?
Although I’m afraid this problem lies on the Americans’ side.
Thomas
Hello Thomas,
Could it still be arranged now so that the names of the airfields, and not just the coordinates, are displayed on the Garmin?
Currently the airfield identifier is only transmitted for public aerodromes. In the medium term this should also be possible for reporting points, radio navigation aids and glider sites.
However, some internal restructuring of our database is still required for this, and we are currently working on it. These changes must first be completed before we can extend the corresponding functionality.
Until then the only option remains the previous method of using raw coordinates, including the associated Garmin-internal accuracy limitations :face_with_bags_under_eyes:
