# VFRnav flight logs
**URL:** <https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353>\
**Category:** VFRnav Support\
**Created:** [July 21, 2026, 10:17am UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353 "2026-07-21T10:17:06Z")\
**Posts on this page:** 15\
**Page:** 1
<div class="post-metadata">
**Author:** ![Dietrich](https://forum.vfrnav.com/letter_avatar_proxy/v4/letter/d/439d5e/32.png) [@Dietrich](https://forum.vfrnav.com/u/Dietrich)\
**Post date:** [July 21, 2026, 10:17am UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/1 "2026-07-21T10:17:06Z")
</div>
Hello, I have a question about where deleted files are stored in VFRNav. Specifically: the flight log from my last flight is no longer available. I may have accidentally deleted it, or it may have been lost for some other reason. Is there any way to recover it?
**Author:** ![KBfly](https://forum.vfrnav.com/user_avatar/forum.vfrnav.com/kbfly/32/28_2.png) [@KBfly](https://forum.vfrnav.com/u/KBfly)\
**Post date:** [July 21, 2026, 11:16am UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/2 "2026-07-21T11:16:51Z")
</div>
Hi Dietrich,
First of all, welcome here.
Have you enabled the synchronization function?
Otherwise, if it’s just a single flight you can also add it manually. If you deleted it, I don’t think there’s a “Trash” (recycle bin).
Clear skies, Karsten
**Post date:** [July 21, 2026, 11:45am UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/3 "2026-07-21T11:45:23Z")
</div>
Hello Karsten, thanks for the quick reply. Do you mean the synchronization feature on the iPad? I probably haven’t enabled it. But no problem, I’ll be more careful from now on.
Dietrich
**Post date:** [July 22, 2026, 6:06pm UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/4 "2026-07-22T18:06:41Z")
</div>
…and every now and then make a backup in KML format! …that’s better.
**Author:** ![Achim](https://forum.vfrnav.com/letter_avatar_proxy/v4/letter/a/ce7236/32.png) [@Achim](https://forum.vfrnav.com/u/Achim)\
**Post date:** [August 30, 2026, 1:41pm UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/5 "2026-08-30T13:41:17Z")
</div>
I think that since the last update VFRNav no longer displays departure and landing airfields. Flight time and route (green line) are shown. Departure and landing airfields only appear as dots. What am I doing wrong, or is it an issue with the app?
Greetings from the Westerwald
Achim
**Author:** ![H655](https://forum.vfrnav.com/user_avatar/forum.vfrnav.com/h655/32/350_2.png) [@H655](https://forum.vfrnav.com/u/H655)\
**Post date:** [August 30, 2026, 2:19pm UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/6 "2026-08-30T14:19:56Z")
</div>
Hello @Achim 👋
the waypoint index probably wasn’t built correctly. It was introduced in the last major update to speed up waypoint search.
Please go to the map management and delete the map that contains the respective airfield. After reloading it the index will be regenerated and it will work again 👍
**Post date:** [August 30, 2026, 5:20pm UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/7 "2026-08-30T17:20:13Z")
</div>
I deleted the Frankfurt map and reloaded it. I’ll check on the next flight whether it works again. Do you have to do that for all maps or just that one?
Regards, Achim
**Post date:** [August 31, 2026, 6:18am UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/8 "2026-08-31T06:18:22Z")
</div>
> [@Achim](#):
> Do you have to do that for all maps or just for the one?
The new maps for September are expected to be released today. With the map update this won’t be a problem anymore and won’t need to be carried out again for other maps.
It would be great if you could drop a quick note after your next flight to let us know whether it worked.
**Author:** ![Heiko](https://forum.vfrnav.com/user_avatar/forum.vfrnav.com/heiko/32/171_2.png) [@Heiko](https://forum.vfrnav.com/u/Heiko)\
**Post date:** [September 1, 2026, 4:45pm UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/9 "2026-09-01T16:45:34Z")
</div>
Hello
That would be great — I had exactly the same problem with the three dots last week.
Heiko
**Post date:** [September 1, 2026, 5:20pm UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/10 "2026-09-01T17:20:30Z")
</div>
Hello Heiko,
happy to test and report back 👍
**Post date:** [September 6, 2026, 9:21am UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/11 "2026-09-06T09:21:09Z")
</div>
Hi everyone, on Friday I went from Elz to Mainz and everything worked again. It was within the Frankfurt map, but I think it applies to the other maps as well.
Regards, Achim
**Post date:** [September 6, 2026, 9:23am UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/12 "2026-09-06T09:23:10Z")
</div>
“others” and “cards”, of course. Fingers too thick or the phone screen too small.
**Post date:** [September 6, 2026, 12:13pm UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/13 "2026-09-06T12:13:58Z")
</div>
…going well​👍
Blue skies, Karsten
**Post date:** [September 6, 2026, 1:56pm UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/14 "2026-09-06T13:56:07Z")
</div>
Hello
Flew today
It’s working again
Thanks
Regards, Heiko
**Post date:** [September 6, 2026, 5:51pm UTC](https://forum.vfrnav.com/t/vfrnav-flugaufzeichnungen/353/15 "2026-09-06T17:51:55Z")
</div>
Thanks everyone for the feedback 👌
Enjoy the rest of your Sunday
