At this point I would like to describe setting up the above-mentioned adapter on my ATR833:
- Hardware installation on the radio
! On-board power off, ignition switch off !
- Release the retaining clips of the SUBD connector at the back of the radio.
- Remove the existing plug
- Plug the adapter connector on
- Lock the adapter’s retaining clips (if necessary you can use a thin cable tie)
- Fit the existing plug onto the adapter
- Lock the retaining clips
- Check: …everything secure?
- Setting up the adapter in VFRnav
Bordspannung an, Funkgerät an<
Turn on phone, tablet, Bluetooth
→ do not try to search for or pair the connection in the phone or tablet’s Bluetooth! This is BTLE, which is not visible here.
Start VFRnav
Settings → Devices → Device connections → # Interface (tap) … search … ATR833_LINK should be found. Select it
(if nothing is found here, see Troubleshooting below)
Settings → Devices → Device connections → # Device (tap) select f.u.n.k.e. ATR833 (tap)
Settings → Devices → Device connections → # Connected no …this should say “yes”. (Note! currently up to version 4.11.0 please ignore the status)
Settings → Devices → Device connections → Settings
Here you can decide whether to transfer the frequency directly as the active frequency -or- as the frequency into the radio’s standby mode. (Matter of preference)
Note: you don’t need to perform these settings later. Unless you want to change something, e.g. regarding active/passive frequency.
- Working with VFRnav
Transfer frequency from the airspace section:
…here the transfer was set to the standby frequency.
Transfer frequency by tapping an airfield:
Note: if the BTLE adapter is actively set up, the airfield frequency appears as a button with light-blue text. If the adapter is not set up correctly, the frequency appears as usual in VFRnav.
Now switched the transfer to the active frequency.
- Troubleshooting
If you don’t enable Bluetooth system-wide on the phone/tablet beforehand, VFRnav will turn on Bluetooth. A permission prompt will appear. I didn’t choose that option; instead I enabled Bluetooth system-wide beforehand.
If the BTLE adapter is not recognised, other Bluetooth devices in range can be a possible source of error. For example, on recent Stratux systems BT is enabled by default. If you know what you’re doing you can, for example, connect from Windows to the Stratux via ssh using the tool Putty and edit the file: /boot/firmware/config.txt
to add the entry or remove the # character before dtoverlay:
# move RPi3 Bluetooth off of hardware UART to free up connection for GPS
dtoverlay=disable-bt
Attention! If you use functions on the Stratux via BT then of course that won’t work.
But since the connection setup with the Stratux usually occurs via WLAN Connect, you should be able to set the above-mentioned entry.
Possible causes of error can of course be a weak battery (tests when the engine is not yet running). (well … this should be remedied anyway.
I hope my tips and explanations were helpful to you. The adapter works perfectly for me. (ATR833)
best regards, simply fly
