The info fields
The info fields are divided into two sections:
  1. Flight information fields
  2. Route information fields
They display the most important navigation and status data during flight and can be customised as needed.
Flight information
Default settings:
  1. Altitude above mean sea level (MSL)
  2. Heading
  3. Speed over ground (Groundspeed)
  4. Time (UTC) or AIRTIME since takeoff
Route information
Default settings:
  1. Distance to next waypoint
  2. Course to next waypoint
  3. Remaining time to next waypoint (ETE - Estimated Time En-route)
  4. Arrival time (ETA - Estimated Time of Arrival)
Note: In the tablet layout the flight and route information fields are displayed together:
  • side-by-side in portrait orientation
  • stacked in landscape orientation
Settings
Each info field displays a specific value.
Many info fields allow a direct configuration of units or display parameters.
To open an info field’s settings, long-press the corresponding field.
Example:
In the Altitude field you can switch between
  • Altitude above mean sea level (MSL) and
  • Altitude above ground level (AGL)
Further settings for:
  • Layout
  • Display size
  • Selection of displayed info fields
can be found under:
Settings → Appearance → Info Fields
