Unable to embed approach charts
Embedding approach charts is not possible; the link appears to be broken
The following versions are in use:
VFRnav: 4.30.2
iOS: 26.7
Hello @Strohmd,
Thanks for your post here in the forum!
Could you test embedding the approach charts again with version 4.30.3?
Clear skies
Thanks for the prompt response; the issue has been resolved in version 4.30.3.
Dieter
With the latest update 4.31.0, it’s again not possible to embed approach charts. The link to the AIP works, but I can’t add them to my maps.
At least the charts that had already been downloaded and now need to be updated. Even after deleting the already-downloaded approach charts, the chart cannot be added again — the button in the AIP list is missing.
Hello @Jule, welcome :waving_hand:
Could you give an example of a place where this problem occurs?
That will help us with the analysis.
Fliegergruss (Fliegergruß)
Thanks!
EDFE is the problem.
Many thanks!
Will be fixed shortly :flexed_biceps:
It’s working again now, thanks for the quick fix!!
