Hi there,
I’m facing an unusual problem
On my last flight the wrong aircraft is assigned.
Is there any way to change the assigned aircraft in a flight record?
When I tap the callsign, I land on the aircraft summary and from there I can only access the settings for it.
If I long-press it, nothing happens.
Kind regards,
Daniel
H655
February 17, 2026, 8:45am
2
Hi Daniel,
If you tap on the flight in the logbook, you’ll be taken to the detail view. At the bottom right there is a pencil icon which you can use to edit the flight details - including the aircraft.
KBfly
February 17, 2026, 8:47am
3
no problem, it’s quite simple:
→ my flights → click on the flight you want to change → click on the pencil in the blue square to switch to edit mode
Then at the top choose the dropdown field for the registration.
and select a registration.
Don’t forget to save!
KBfly
February 17, 2026, 8:50am
4
…overlapped with Hermann:rofl: …well, two’s better than one….
Morning Hermann and morning @KBfly
How could I have missed the blue button?
Thanks, you two. I never asked.
Have a great week.
KBfly
February 17, 2026, 9:34am
6
No problem at all! …you sometimes overlook things.
You can always ask here.
Clear skies,
