On my iPad 6 the search for airfields and waypoints in the flight planner no longer works properly.
When you type something into the search field at the top, VFRnav only finds one or a few airfields (those whose name contains the entered text) and these are also the wrong ones. It no longer finds most of them. Example: you type w-o-r-m and Pellworm appears. If I then type an ‘s’ because I was searching for Worms, nothing happens and the display stays empty.
Loading saved routes still works fine, only entering/creating new routes no longer works.
Could it be that the current version I recently downloaded on the iPad still has bugs? On the iPhone everything still works fine.
What can I do?
If I reinstall VFRnav, can I somehow back up the logbook, the already saved routes, my settings and especially the profile of my saved aircraft so that I don’t lose everything after a reinstall?
I’ll jump in ahead of Hermann @H655 (he will still reply to you here). So you’re typing w-o-…? …and not wor… for Worms?
Regarding backups: I’ve mentioned this here several times before:
Please back up your logbook and other data regularly!
My Flights->Export logbook->Choose format (I recommend the KML format, because it also contains the tracks for your flights.) …It doesn’t hurt to also save the Excel format afterwards.
Note: as I just answered the other question, it’s also advisable to back up your own WPs (if you have created any)
On Android you find Worms by entering Wor… Then you already see Worms. …W-o-r- leads you astray and doesn’t make any sense.
Hmm, it’s difficult to describe, but I’ll try again.
When you type something at the top of the flight planning screen, VFRnav already starts searching after the third character entered, finds matches in the database that fit the text and then shows those destination(s) below as choices. It has always worked like that and it still works on the iPhone.
That also used to work on my iPad. But since the last update I installed there, it no longer works. The database that normally contains all potential destinations/waypoints seems to be only partially present or searched. Many destinations are missing.
This manifests as follows:
If you type “W” in the search field, nothing happens yet. If you then enter the next letter “o”, nothing happens either. As soon as you enter the next letter “r” and the search field now shows “wor”, VFRnav displays all destinations that contain that letter combination, i.e. “Worms/EDFV, Wörth/EDWÖRT, Pellworm/EDHP”.
On my iPad, however, this no longer works. There only “Wörth/EDWÖRT, Pellworm/EDHP” are shown and “Worms/EDFV” is no longer displayed.
If you then type the next letter into the search field, e.g. “m”, only “Pellworm/EDHP” appears in the selection list under the search field. Worms no longer seems to be recognized.
This happens with many destinations. Some seem to have been swept out of the database, or can no longer be entered and are therefore no longer selectable as destinations.
Since I’m not handling Apple, Hermann will get in touch. Strange, though, that it works on the iPhone. …and the search for: EDFV …doesn’t work either? …Or does it?
actually, if you enter EDF, many results come up; if you enter EDFV, only Worms remains. That search seems to work.
Only the search by the text name apparently doesn’t work.
Why it works on the iPhone but not on the iPad I can only explain like this:
On the iPad the App Store showed an available update for VFRnav, which I then downloaded and installed.
On the iPhone the App Store showed NO available update, which is why the “old” / previous VFRnav version is still installed there. Everything continues to work fine there.
If the search was revised, maybe that has so far only happened in the iPad version?
It would be good if you could briefly list the currently installed versions on iPhone and iPad here. I’ve asked a colleague who also uses an iPad to try to reproduce it.
Although for full-text search the program shouldn’t care whether it’s an iPad or an iPhone… let’s wait and see what the colleague says.
Worms should be the Frankfurt map, right?
Have a look in Map Management to see whether the Frankfurt map is downloaded. If it is, delete it once and download it again. I think that should solve the problem
Edit: oh yes, as Karsten already wrote: please always include the version information
that was probably it. Somehow the Frankfurt map data must have been corrupted during the last map update. Bad luck, but luckily the error was easy to fix and I don’t need to do a reinstall. The world can be that simple.
Sorry that I forgot the version. It’s the latest for the iPad, VFRnav 4.30.3.
Many thanks to you and Karsten for the help. As always you were prompt and precise in narrowing down the problem.
Oh, one more question: Is there a way to back up the saved routes and aircraft profiles and re-import them if a reinstall is necessary?
Because you use two devices, I recommend using VFRnav’s synchronization feature! That way both devices will be “in sync”. If one device fails, you can restore the state with a single click.
