I have installed VFRNav on 3 devices, and on one it seems that a map update no longer occurs. Checked by runway direction LOGF new 12/30, old 13/31. Two devices show 12/30 correctly (all V4.29.3, Android 11, Android 17), one shows the old information 13/31 (V4.29.3, Android 16). No use of SD cards!
I have already tried clearing the app cache (3x) and rebooting the tablet. No change. On the affected device the maps directory shows “Latest Version”. No version info is displayed for the maps.
Kind regards
PS: In this context I’m also submitting a feature request to show the map version.
that was a very good hint from you Thanks for sharing this observation — I was able to find a possible cause.
Question: Can you delete both AT entries one after the other and then re-download this card? After that, is there only one entry and the correct version?
Version 4.29.4 should reach you over the course of the evening.
When you have a moment, please test the map update — and the prior deletion of the maps — again with this version and let me know briefly whether the problem is fixed.
I’m also having an issue with VAC cards not displaying: the corresponding box is checked in the settings, but nothing appears. I do have the version from a few days ago.
Could you please describe your “problem report” here in a bit more detail? Do you mean Visual Approach Charts? Which “checkbox” where?
You can see, a bit more detailed content and, if applicable, a screenshot would help immensely.
…and regarding the “installed version”…the same applies!
