[Release] VFRnav 4.13
Based on the recently released 4.13.0 version, VFRnav 4.13.2 adds a range of improvements and new radio integrations.
:sparkles: What’s New?
  • New: In planning mode, the vertical airspace profile now includes an offset at the beginning and end, so departure and destination airfields are fully visible
  • New: Added support for TRIG TY91 and TY92 radios via compatible Bluetooth adapters
  • New: Added support for other radios that use the SL40 protocol
:wrench: Changes & Fixes
  • Change: The North-Up offset in the moving map is now enabled by default
    → You can manually disable it in the map settings
  • Fix: The PIB (Pre-Flight Information Bulletin) now correctly includes aircraft params and wind data
