H655
November 24, 2025, 8:20am
1
This release focuses on improving stability and fixing several issues reported by users — along with a useful new enhancement for flight planning.
Fixes
Fix: KML export failed for fields containing special characters
Fix: Bluetooth devices did not automatically reconnect on startup
Fix: Infinite loop when generating a PIB in two-column layout
Fix: METAR/TAF text display in dark mode
Fix: Unable to insert a new line in the Weight & Balance envelope field
Fix: Aircraft selection dialog displayed incorrectly in dark mode
Fix: Connection to older AirConnect devices could not be established
Fix: Menus on some iPads closed automatically after opening
Fix: OpenAir airspace files not shown on map (v4.19.1)
Fix: load route with custom waypoints does not work (v4.19.1)
Fix: crash at fuel settings dialog on iOS (v4.19.1)
New Feature
New: The fuel calculation now allows entering additional fuel and reserve quantities , enabling more precise planning
As always, if you encounter any issues or have suggestions for improvement, we’d love to hear from you — either by email or here in the forum .
Blue skies and safe flying!
– Your VFRnav Team
H655:
Great! Thanks. Now it’s working for me too. I really, really like the two-column view.
Great, just installed.
But am I blind?
Where can I enter the extra fuel?
I was able to enter reserves or surcharges in the aircraft settings. As always: superbly sorted!
Ah, great. I didn’t look there, but in the flight planning, during the calculations.
Automated per aircraft is, of course, also a great solution.
A half-hour buffer + reserves for climb, taxi, etc (just input the worst case) and then it works.
Great solution. I like it.
SonjaG
November 24, 2025, 5:42pm
6
SvenEDRY:
Plane settings
Thanks Sven!! I found it there as well.
So you enter 30 minutes under ‘Reserve’ there and then it’s taken into account in every plan, is that right?
Thanks!
tomtom
December 3, 2025, 2:22pm
7
If you could now inform the system whether you are merely overflying a waypoint on a polygon flight or actually landing there, the fuel calculation could also incorporate the surcharges here.
…. Haihoooo …. in the airspace cut the waypoints are visible !!! ….
… … Thanks to you all ….. really brilliant … especially for the “quick” planning ….
Version 4.20.0
Ahoi
Andi
