Synchronisation and data backup
Wie genau funktioniert das? Wann wird in die Cloud geschrieben? Bei jedem Erfassen eines Flugs bzw. wenn das Tablet wieder online ist? Oder wenn ich “Jetzt synchronisieren” auswähle?
Und importiert wird automatisch, oder muss ich dazu “Jetzt synchronisieren” auswählen?
Weitere Einstellungen (außer Luftfahrzeug) werden nicht gesichert? Also alles unter “Einstellungen”?
Danke und Grüße
Maik
Hello Maik,
die synchronisation ist in der bisherigen Testphase gekoppelt an dem manuellen Anstoß über den synchronisations-button. Das bedeutet, dass bislang kein automatischer Sync erfolgt. It is only planned for this spring.
The sync button is - with synchronisation enabled - included in the sync settings, in the aircraft list, in the list of saved routes and in the “My Flights” list. The synchronisation contains the data you mentioned: saved routes, the aircraft and the flight entries.
We consciously decided against synchronising the settings. There are setups in which different devices are used, for example for different aircraft and their settings. A full settings sync does not always fit. In addition, settings are, as a rule, only rarely adjusted.
Flyer greetings (Fliegergruß)
Many thanks. But I still don’t understand how the synchronisation works. Does the button trigger the import of the data? If so: what triggers the export?
Thanks and regards
Maik
Hello Maik,
By synchronising, the above-mentioned data are stored on our server. With each subsequent synchronisation (e.g. from another device), new or changed data are compared with this dataset and updated accordingly.
Pressing the button therefore triggers both an export (if data in the cloud are older than those on the device) and an import (if newer data from another device are present in the cloud).
I hope that’s made things a bit clearer.
If not, please feel free to write again :grinning_face:
Aviator’s greetings and have a nice weekend
