Hello Mr Hölter,
Track and Bearing are actual course and desired course, as I understand it.
In my professional environment I usually see the desired value first, then the actual value.
On your screen this is reversed. I see Bearing first and then Track. Each time I have to pause and think. Could these display fields perhaps be included in the respective parameter settings so that I can display the fields in the upper or lower row?
To make matters more complicated, the line with the display fields –Waypoint Distance Bearing ETE– and the line with the display fields –Altitude Speed Track Clock– are not displayed one above the other, but at the very top and the very bottom of the screen.
This means that for this detail the eye has to travel from top to bottom and search for the values.
IF the desired/actual course values were directly above each other, i.e. the two lines were directly one above the other, these two navigation-critical displays would be comprehensible at a glance.
That may sound marginal, but once you have experienced the advantage of having both important navigation values one above the other, you will not want to do without it.
Perhaps this could be made configurable.
Best regards for your holiday,
Harald
