Weight and Balance
Heyho,
Me again :joy:
During flight school I always accounted for the empty tank in the W&B (weight and balance) calculation.
Maybe one could also include this and a third point in the W&B?
The weight at takeoff is already in the table.
Let’s call it point T (for TO)
We also know how long the route is planned to be. With the specified consumption you can enter point L (for LDG).
And it’s also known what the total amount of fuel on board is. Setting that to 0 then gives point E (for Empty).
That way you have the takeoff mass, the planned landing mass and the mass if the tank is empty and can see that everything is OK.
Or is that too much? :thinking::joy:
I’ve learned that too:
Weight & Balance during takeoff and landing with reduced fuel quantity.
If we look at it very soberly, without all the bogeymen á la “if something happens then it’s on you” and “ohhh, the insurance will be pleased” or “grounded after a ramp check”: When does this really become relevant for us VFR pilots?
Typical charter and club aircraft with wing tanks (near the CG) have virtually no CG shift.
That leaves fuselage tanks as a “little problem”. But here you know after the third W&B calculation that when landing solo you should still have x litres left.
I think in 95% of cases this is (for us) more of an academic issue.
@KaBaPilot This is absolutely not meant as a judgement of your post or you as a person. Just my personal opinion on the topic :slight_smile:
At the moment I’m still in testing, but I’m considering purchasing VFRNAV.
To eliminate paper planning, I’m still missing two vital items:
(I fly in a mountainous region with an aircraft type that has a center tank in front of the pilot)
  1. The center of gravity calculation must display the tank fuel level as a straight line on the graph. With baggage, the aircraft could become tail-heavy when the tank is empty.
  2. Takeoff and landing distance depends on density altitude. A calculation of this, including other factors, is important. Tabulated with custom safety margins
2 posts were merged into an existing topic: Feature Request: Flugzeit in Flugbuch Flug-Details anzeige
Hello @socius111 ,
welcome to the forum :waving_hand:
I have merged your post with that of @KaBaPilot.
Regarding center of gravity calculation: Which aircraft are you flying?
17 posts were split to a new topic: Hilfe bei Weight & Balance Eingaben
Hello and thanks for the feedback. Mine is a BREEZER b400-6. It has a fuel tank in front of the pilot with a negative moment arm. During flight, as the 75 L of Super is consumed, if the large baggage compartment is used a tail-heavy condition could theoretically develop that was not present at takeoff.
Best regards, Sönke
Important for density altitude and general takeoff and landing distance calculations: example mountain flying, altiports, warm summer, high in the mountains, limited grass runway, etc…
Should be able to be taken into account.
I can understand @molta’s point of view and largely agree with him. The flight-related effects of a shift in the center of gravity due to fuel burn are rather small for most common VFR aircraft.
Nevertheless, I think: if we’re already performing the calculation anyway, it doesn’t hurt to also take the influence of fuel burn into account.
Here’s a first draft/proposal for a possible presentation:
Any suggestions or ideas?
That looks really, really good!
I think that’s great. I like it.
yup, thumbs up from me too :+1:
Thumbs up from me too… looks good and functional.
:+1:
Thanks for extending the feature — I think it’s very important.
If all values are already being calculated, why not also for the Zero Fuel situation?
The legend could be omitted, since it takes up space and the association becomes obvious from the decreasing mass.
