Weight & Balance
Weight & Balance has been integrated into VFRnav.
To make this evaluable for flight planning, proceed as follows:
First, select the respective aircraft in VFRnav to enter the baseline values.
w&b0
Then activate the gear icon next to the aircraft:
w&b1
In the aircraft configuration page, navigate to the Weight & Balance menu item
w&b3
On the following page, fill in all the data. The corresponding values can be found in the latest weighing report and in the aircraft manual. Note: please scroll down at certain points if necessary to see more fields.
w&b4
Of course, you update the fuel values and the pilot weight for each flight.
To do this, go to Flight Planning → Calculation.
Here, click on the aircraft registration and enter the corresponding values.
lfz
lfz2
Then, in Flight Planning under -Calculation-, you can generate the PIB and see the integrated Weight & Balance. Here you can see whether you are within the limits (green dot positioned accordingly) or outside of the limits (dot turns red accordingly).
w&b2
You can print the whole thing or share it as usual.
simply fly and pilot greetings,
Thanks, Karsten, as always, superbly written :ok_hand:
I was also very pleased that it is now possible to do a proper W&B calculation.
For this I have a small feature request: Negative values for lever arms.
I fly an aircraft (Breezer) that has the tank in front of the datum (reference point). More fuel therefore corresponds here to a negative moment.
I think this can easily be solved by removing the restriction to positive integers.
Otherwise: many thanks for this great product!
Hello @Zydo,
a warm welcome to the forum :waving_hand:
Negative levers should in fact be possible and have been tested accordingly on our test devices:
Could you please provide more detailed information about your device? That will be device- or manufacturer-specific.
Hmm, you’re right. It’s very likely an iPhone problem and not the software itself.
For me it simply follows from the fact that a numeric keyboard is displayed for the input that only allows 0–9. No commas or sign characters.
Ah, okay - I had only quickly tested it on Android.
I will adjust this on the iPhone/iPad accordingly and provide an update.
Thanks for the heads-up. If you notice anything else, please post again here on the forum.
I’ve just found a workaround for myself. Actually two.
  1. copy&paste from the clipboard
  2. Use the scan function for input (e.g. write -550 on a piece of paper and have it inserted).
Works.
Thanks for the ultra-fast responses!
That’s clever :grinning_face_with_smiling_eyes:
