Could you add the RMZ (Radio Mandatory Zone) to the airspace warnings? Anyone who doesn’t want it can, like the others, disable it. I would find that very handy…
In another navigation app there are warnings for the route, e.g., when minimum flight altitudes are not observed or when the route accidentally enters an ED-R area… I would love that too!
Thanks for all the effort and for continuing to develop VFRnav!!!
thanks a lot for your feedback and your suggestions!
I think we can do that It’s on the to-do
Could you describe this suggestion in a bit more detail? Do you mean that when someone plans a route, a notification appears if it crosses an ED-R (restricted area) or similar?
re 2.) What I mean is that during route planning a warning should appear if you accidentally cross an ED-R. However, since you normally check the route anyway, it occurs to me that this feature would only really make sense for, for example, ED-Rs that are active only on certain days or times of day. That would, however, require being able to plan a route for a specific day or time, so it’s a bit more effort than I initially realized. A warning about minimum altitude would also be nice, but the manual check has actually become much easier thanks to the vertical view. In that sense… it was just a suggestion that would need a bit more thinking.
